Will Accessories from Mark IV transfer to Gen 6 >
Old 09-10-2009 | 12:43 PM
Default Will Accessories from Mark IV transfer to Gen 6
I have been looking at a couple Gen 6 engines, are the bolt holes in the same place for all the V-Belt accessories? Will the 3groove pulley on the balance bolt on?
I know they is no provision for fuel pump.
1BIGJIM is offline
Old 09-10-2009 | 02:06 PM
Wobble's Avatar
SORE MEMBER
I think everything matches except a couple of holes are 3/8 instead of 5/16. I have done that swap in the past and only had to find a couple of bolts as I recall.
Wobble is offline
Old 09-10-2009 | 02:09 PM
Default mfixxall
yes everything will swap over..
FIXX is offline
Old 09-10-2009 | 02:14 PM
jfm
It all lines up. I did a full serpentine kit on a Mark IV block no problems. I don't know about the bolts cause I just replaced them all with new. Other than that it all lines up.
jfm is offline
Old 09-10-2009 | 03:02 PM
Thanks!
I see no reason to not go to a pair of 540's, the wife will never know the difference
1BIGJIM is offline
Old 09-11-2009 | 07:54 AM
Everything will match up with the exception of having to open some 3/8 accessory holes up to 5/16 as wobbles previously said.
eichhoma is offline
Old 09-11-2009 | 08:44 AM
Yes.... but You will have open all the accessories hole to 7/16 not 5/16 it is very easy to do all you need is a cordless drill and a 7/17 drill bit and new bolts. been there and done that for last engine build.
Rockfish71 is offline
Old 09-11-2009 | 02:38 PM
You may also have to do something about your oil cooler adapter and hoses if you are using the stock Mercruiser type.
Gen 4 uses a filter adapter plate with 2 bolts. Gen 6 is setup like a Ford with the filter screwing on to a pipe thread straight into the block. The stock Gen 4 oil cooler adapter will not work with this. You will need a different adapter and oil lines.
bigalhenry is offline
