Best product to remove stickers from fiberglass Gelcoat >
Old 09-10-2009 | 05:13 PM
Default Best product to remove stickers from fiberglass Gelcoat
What is the best product to remove the residue off of the fiberglass Gelcoat once the original stickers have been removed, what should be done after the old stickers are removed and the new stickers are installed to protect the Gelcoat and new stickers?
scarabsc is offline
Old 09-10-2009 | 05:42 PM
Hauling Trash's Avatar
Acidtone
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 09-10-2009 | 05:55 PM
FASTTIMES's Avatar
3M Adhesive Remover works well
FASTTIMES is offline
Old 09-10-2009 | 06:30 PM
Wobble's Avatar
SORE MEMBER
+1
best product short of gasoline I think
Wobble is offline
Old 09-10-2009 | 06:47 PM
Sticker Off
schnydo is offline
peanut butter
dreamer is offline
Old 09-10-2009 | 06:57 PM
FunHome's Avatar
3m Adhesive Remover and a fingernail....
FunHome is offline
Old 09-10-2009 | 07:06 PM
soyclean mastic and adhesive remover spray it on, let it sit, and then scrape it off with a plastic spreader or plastic razor blade
Timeless61 is offline
Old 09-10-2009 | 07:15 PM
bcfountain's Avatar
Registered User
sticker shock.you can get it at autozone.
bcfountain is offline
Old 09-10-2009 | 07:25 PM
Not really a product, yet a tool. I have one that my friend used the entire wheel on removing graphics from his boat. Did an amazing job (graphics were nearing 12 years old)
http://www.mactools.com/product/tabi...22-mb6901.aspx
Edit: Just read that you already had the stickers off, anything above will work, also try goof off
prostock85 is offline
