fuel flow meters
Old 09-12-2009 | 09:57 AM
Default fuel flow meters
does anyone have one on their boat? would be nice for cruising to see consumption given different variables. can anyone recommend one? thanks (single engine, carbureted)
plastic1 is offline
Old 09-12-2009 | 12:24 PM
2112's Avatar
http://www.floscan.com/html/blue/ser...ail.php?sid=14
You have to call, they don't answer e-mails.
2112 is offline
Old 09-12-2009 | 08:56 PM
jeff32's Avatar
I got flowscan and it works fine for me!
jeff32 is offline
Old 09-13-2009 | 01:15 AM
rbtnt's Avatar
I have a Northstar F310 that I connected to my handheld GPS to get MPG along with flow.
http://www.starmarinedepot.com/North...orer+Fuel.html
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 09-13-2009 | 08:11 AM
Payton's Avatar
Charter Member #927
I've got the Northstar system. It works great. You just have to get the right size for your horsepower. It's more accurate that the fuel gauge.
Payton is offline
Old 09-13-2009 | 12:08 PM
2112's Avatar
How would you connect the Northstar sensor into a size 12AN fuel line? They didn't show the sensor on the link. Also, do you have a source to determine the size for your power?
2112 is offline
Old 09-13-2009 | 01:38 PM
I have meters on my boat. They are accurate and they keep track of fuel usage. More accurate than my tank gauge. I upgraded my power over the winter and the meter would be too restrictive for 750hp. They are for sale if your interested.
baja502x2 is offline
Old 09-13-2009 | 09:54 PM
rbtnt's Avatar
Here's a link to Northstar.
http://www.northstarnav.com/en/Produ...ent/F310-Fuel/
For Product Related Concerns (Technical Support and Repair Services):
PHONE (Toll-free in US) - 1-800-NAVIG8R or 1-800-628-4487
PHONE (Direct) - 603-324-2042
They do not have much info listed on their site. I'm using the 310 meter on low hp engines for testing only, so I use rubber hose and clamps.
rbtnt is offline
Old 09-15-2009 | 11:30 PM
2112's Avatar
I finally got a response from Floscan (I tried a different person) and they were shocked I had a return fuel line on carbed motors. I will need to double up on everything to do it.
2112 is offline
Old 09-16-2009 | 01:00 AM
aTX427's Avatar
They are really nice to have when trying to optimize economy with different trim, tab and rpm combo's. Just don't look at them when you are running at WOT. You may also want to look into the Livorsi digital prop slip gauge. They are great for fine tuning as well.
aTX427 is offline
