Bounceing trailer
Old 09-12-2009 | 03:12 PM
Default Bounceing trailer
Recently purchased a 25' boat and when trailering it will start bouncing pretty good if I hit a bump or get on some concrete highways. The trailer has mono leaf springs and I never seen this before on a trailer. Tire psi is correct, I am wondering if the springs are getting weak. Any ideas?
placecrafttim is offline
Old 09-12-2009 | 08:54 PM
jeff32's Avatar
too much weight in the back of trailer?
jeff32 is offline
Old 09-12-2009 | 08:59 PM
jeff32's Avatar
or not enough ply in your tire. that has to be a better bet than too much weight in the back...
jeff32 is offline
Old 09-13-2009 | 12:22 AM
Velocity Vector's Avatar
Crazy Energy
If the trailer is level and 8-10% of the weight of both the boat and trailer is on the tongue it would have to be something else. Go to the junkyard and get some multi leaf. If a mono breaks, loss of axle control. Catastrophic if it happened at speed. The single leaf are smoother and last a very long time. If you wait for something to look broken before working on it, the multi-leaf will probably warn you before something really bad happens. Junk yard is full of them if you decide to swap.
Velocity Vector is offline
Old 09-13-2009 | 06:13 AM
Audiofn's Avatar
Charter Member #232
West Marine probably has a pair of leafs in stock. I also would go with a multi leaf. I have never seen a single leaf under any boat unless it was a very old trailer and certainly never in a boat that is 25 feet long.
Put your best foot forward!
Audiofn is offline
Old 09-13-2009 | 07:22 AM
Default multileafs
Friction between the leafs on a multileaf spring acts to dampen the spring forces, very much like a shock absorber. The ride motions have to be damped somehow. Randy
bustedbrick is offline
Old 09-15-2009 | 04:54 AM
mama tryed's Avatar
also check and make sure your tires are balanced.
mama tryed is offline
Old 09-15-2009 | 10:42 AM
Audiofn's Avatar
Charter Member #232
I have never seen trailer tires balanced Mitch is that normal?
Audiofn is offline
Old 09-15-2009 | 10:55 AM
Or did you mean is Mitch NORMAL
Answer = Absolutely NOT ........
Old 09-15-2009 | 11:38 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I don't usually balance my trailer tires with weights & such.
However, I will request that they put them on the balance machine and make sure that they are not WAY off. If so, I'll have them rotate the tire around the wheel 90 or 180 degrees to get them somewhat better.
Sydwayz is offline
