Max cubic inches out of Bowtie block ? >
Old 09-12-2009 | 04:21 PM
Donman's Avatar
Default Max cubic inches out of Bowtie block ?
What is the maximum cubic inches you can get from a Bowtie 502 block and what pieces do you need to get there ?
Donman is offline
Old 09-12-2009 | 08:39 PM
Bore 4.560 if you sonic test and a 4.25 crank would be safe. 557CI
DonRoc is offline
Old 09-12-2009 | 10:50 PM
Griff is offline
Old 09-12-2009 | 11:28 PM
CB-BLR's Avatar
Chris
Originally Posted by Griff
588
4.56 Bore
4 3/8" stroke
Chris
CB-BLR is offline
Old 09-12-2009 | 11:48 PM
Personally, I wouldn't put a 4 3/8 crank in a 9.8 deck height block. The rod angle is to steep for my taste. I would stick with a 4.25" crank and you could go all the way to 4.600. That would make a 565 ci. You can take that block to 4.625" bore as long as you sonic test it. You should still have .250-.300 wall thickness at 4.625" bore. I have taken countless bowties to 4.600 with no problems.
Eddie
Young Performance is offline
Old 09-13-2009 | 12:11 AM
I had a 502 bowtie at 4.600 with stock crank (think it worked out to 525 cu.) ran great with an easy 600 hp/600 ftlbs. at 9:1 compression with Dart intake and EMI exhaust. Loved that engine!!
raeburn is offline
Old 09-13-2009 | 12:38 AM
That would make a 532 ci.
Eddie
Old 09-13-2009 | 08:25 AM
Payton's Avatar
Charter Member #927
Could you guys explain Sonic Testing? Are you checking the thickness or strength of the cylinder walls? And you do this before boring, right? Otherwise you've ruined a block that could be used with less bore. Am I close?
Payton is offline
Old 09-13-2009 | 08:54 AM
Donman's Avatar
Thanks for the input guys.
Donman is offline
Old 09-13-2009 | 12:00 PM
Yep, sonic testing will check for wall thickness.
Griff is offline
