Water In The Cylinders (help)
My 1996 Mercuriser 7.4s Sea Water Pump Froze Up And Now I Have Water In The Cylinders But Not All The Cylinders, But It Has Water In The Cyliders On Both Sides And Doesnt See To Have Water On The Oil Dip Stick
what kind of boat is it and when did you discover this? unsure of the boat you have and how your exhaust exits but you didn't have it beached did you? how did you discover your sea water pump froze up? have you done anything else to the engine or hose routing recently? how much water was or is in the cylinders and what ones? seems strange to have both these things happen near or at the same time. do you have the heads off or did you roll the engine over with the plugs out? if the heads are off did you check the gaskets? also intake gaskets???
Get your heads off quick and get the water OUT!!!
If you've waited long enough for a response before doing so, it may already be too late, unless it's fresh water. Either way, get the heads off, dry the block out and drain it completely, I used some water dispersant while doing so just to be sure, then drain the block again, flush it a few times and do it all over again.
Let us know how you go.
Good luck!
Good luck!
what happened is i forgot to put oil in the fuel pump its the one on the sea water pump and it froze up and im assuming thats why the motor got hot , i took the plugs out and water came out of a couple of the spartk plug holes
he probably has the fuel pump/water pump combo that has a small oil reservoir.
Long time cult member.
