454mag MPI heads help (motor heads)
Hey, motor guys.. Ok I got stock twin 454mag MPI's in my 312Formula.. I have Gill offshore Exhaust and Vortech MPI Breathers.. I want more oommff and some top end. Some say that the stock heads on these Mag MPI's (roller cams too) are good to port, pocket and put larger valves in.
Or should I just go with an after market Alum head set up Like CamField.
anyone know of some good set ups, valve sizes etc. even cam info
Not looking for a race motor dependable power.
those are stock rectangle port heads on there ?
if so
you can spend a little money on them and have them ported and worked over, they will make some good power for you if done correctly and setup with the proper cam and valvetrain
go with a custom cam from Bob Madera at Marine Kinetics well worth the money, just give him your engine specs and power goals and he will take care of the rest
if you need any port work done I have a local guy who is great at it, if you want pm me i'll put you in touch with him,
this will probably end up being cheaper than going with aluminum heads, especially if you have 2.19, 1.88 valves in those heads already (which you might have)
if so
