BBC starter bolt pattern? >
Old 09-15-2009 | 10:56 PM
Default BBC starter bolt pattern?
Is there a starter that uses the side by side bolt pattern for the bbc in marine application. ? My inside threads are messed up on the staggered bolt hole.
My Addiction is offline
Old 09-15-2009 | 11:19 PM
Strip Poker 388's Avatar
Rob
Does yours use 3 bolts?
My tilton is side beside,2 bolts,most of that style are that way I believe
Attached Thumbnails BBC starter bolt pattern?-dis-asmy-12-5-08-138-large-large-.jpg   BBC starter bolt pattern?-whipple-12-24-05-teardown-042-large-.jpg   BBC starter bolt pattern?-boat-3-4-09-048-large-.jpg
Strip Poker 388 is offline
Old 09-15-2009 | 11:35 PM
Velocity Vector's Avatar
Crazy Energy
These guys may,
http://www.motorcityreman.com/marine...-starters.html
Velocity Vector is offline
Old 09-16-2009 | 12:32 AM
Any of the mini high torque gear reduction starters use a side by side pattern.
Eddie
Young Performance is offline
Old 09-16-2009 | 03:26 AM
I just bought the CVR starter to replace mine. It has side by side bolts and will fit any Mk IV to Gen VI block aparently. I thought I had to ge tthe staggard one but I didn't.
Ghostrider is offline
Old 09-16-2009 | 10:16 PM
Eddie
mine is an Arco and it is staggered.
Thanks guys!!!
Old 09-16-2009 | 10:52 PM
Default mrfixxall
Thanks guys!!!
If your going to use a side by side starter make sure you hook up the bracket to the end of the starter motor that attachs to the block..that style starter is not as stable as the staggared one.
FIXX is offline
Old 09-17-2009 | 07:29 PM
Rob
Originally Posted by mrfixxall
If your going to use a side by side starter make sure you hook up the bracket to the end of the starter motor that attach's to the block..that style starter is not as stable as the staggered one.
Ive never had any problem not using the bracket,Scarab 12 years,Hustler 8 years,Camaro drag car 10 years,Chevelle 20 years.http://www.powermastermotorsports.co..._starters.html
But it cant hurt
Old 09-17-2009 | 08:07 PM
Default mrfixxall
But it cant hurt
i have 1 time,the starter rocked and broke the outter bolt hole on the block..and thats how i figured out why they had the tab on the rear of the starter.
FIXX is offline
Old 09-17-2009 | 08:25 PM
Rob
would that be form it kicking back?
The tab on a stock style starter ? I havent seen a tab on a highperformance starter.
