leak down test >
leak down test
leak down test
Old 09-16-2009 | 04:26 PM
Default leak down test
can anybody tell me what would acceptable leak down on a marine blower motor
sport is offline
Old 09-16-2009 | 06:41 PM
They should be within 10% of each other. I like to see under 15% with some time on it, around 6-8% new. Just a guide. a blower motor should have the same leakdown numbers of a N/A. The rings should still seal, and so should the valves.
What problems are you having, blow by, low compression?
DonRoc is offline
Old 09-16-2009 | 08:47 PM
no problems but leak down is 9-11% did'nt know if that is bad or good 300 hrs.
sport is offline
Old 09-16-2009 | 09:06 PM
Thunderstruck's Avatar
I would say that is good for 300 Hrs. Could you tell where the air was leaking? Rings, intake valve or exhaust valve?
<10% is good.
Was the motor cold or hot? If it was cold even better.
Long time cult member.
Thunderstruck is offline
Old 09-16-2009 | 09:26 PM
Default mrfixxall
+2 good to go! my question is,blower motors+300 hours..alot of stress on the lower end..may be time to check things out so you have no future problems..
FIXX is offline
Old 09-16-2009 | 09:31 PM
300 hours on a blower motor, it's not bad. but yes where it is leaking is important. With 300 hours I would not feel bad freshening it. Cheap insurance.
DonRoc is offline
Old 09-16-2009 | 10:10 PM
i did run the motor but it does not get real warn with the muffs and the hose because it has an open cooling system with no thermastat. it has 125- 130 compresson in all cyl at 5000 feet
sport is offline
Old 09-17-2009 | 01:08 AM
The numbers sound good to me, especially with 300hrs on it.
Griff is offline
