Trying to check timing, but can't read the harmonic balancer.....
I want to check the timing on my 502 mpi. But the balancer is too rusty to see any numbers on it. From what i can tell, there is a 60 on the far right side, and i can see where the ticks start on the left. I can also see the two grooves but don't know what degree those are. One looks to be in the 6 degree area, the other in the 30 degree area, but I can't tell? Any help here.
marks are on the balancer. I've figured out with some chalk what is what. I ran the motor at 1700 rpm's with a and b shorted out. Looks to me that the timing is set at 14 degrees. Its supposed to be 8......... Do I have a sensor that is throwing the timing off?
