Precision Marine 540 ci/560 hp /KE bellhousing , new BW trans >
Old 09-21-2009 | 04:54 AM
Default Precision Marine 540 ci/560 hp /KE bellhousing , new BW trans
assembled and dyno by PRECISION MARINE 560 hp / 600 ftlbs tq to 4300 rpm
KE engine mount, Merlin II 9.8 block /steel caps, Eagle 4340 crank/rods , JE pistons, 9/4/1 comp, Merlin intake , Holley 950 hp carb , KE flame arrestor , KE/Canfiled heads ,2 piece covers hardcoated ,Crane 1.7 golds ,COMP p-rods , Crane roller lifters ,731 cam, ATI balancer , KRC ps pump , -12 oil lines , KE oil pan, hp6 filter.. KE on the front end , brackets etc ,KE bellhousing , bronze raw pump ,hp 500 carb wire harness NEW BW trans , NEW TRS tailstock , all NEW MSD ignition system , Phillips wires, stainless ignition mount , SM gen 2 manifolds , NEW 40" dry pipes , rings ,dumps.. custom pre-oiler system with filter ,ready to drop in ,needs a day to install your senders of choice/ belts adjust and wire to your liking...
used parts in this package , -flywheel , raw pump bracket ,oil filter head , manifolds had about 40 hours on them
$10k for all
eric @ 986-774-1005
open87 is offline
Old 09-21-2009 | 06:16 AM
Is that a B.W. 72. How are you controlling water temp? I'm just curious
motor is offline
Old 09-22-2009 | 06:06 PM
yes , it's a 72c , engine uses a oil thermostat to control oil temp. see pic
open87 is offline
Old 09-22-2009 | 07:53 PM
WOW. what a nice looking and well thought out set up. looks like you like perfection. very nice package.
john
getrdunn is offline
Old 09-23-2009 | 04:59 AM
thanks , built to be very reliable and bullet proof...rigged it to be as neat and tidy as possible...
open87 is offline
Old 09-24-2009 | 02:11 PM
needs to go!
open87 is offline
Old 09-26-2009 | 04:13 PM
engine sold.
open87 is offline
