Billet 525 EFI pulleys >
Old 09-21-2009 | 09:32 AM
Wild's Avatar
Default Billet 525 EFI pulleys
anyone make Billet 525EFI replacement pullies
I tried Eddie, Teague
Wild is offline
Old 09-21-2009 | 10:44 AM
I've not had any experience with these guys, but ran across this:
http://www.bullet.on.ca/part_upgrade.html
Good luck.
skmulligan is offline
Old 09-21-2009 | 11:14 AM
Default mrfixxall
or you can try matching somthing from thease guys...
http://www.billetspecialties.com/ite...id=283&pid=704
FIXX is offline
Old 09-21-2009 | 11:20 AM
CP Performance has the nicest setup. They are not cheap, but anything that is that nice won't be cheap. The thing I like the best is that they use a mandrel on the p/s pump and sea pump. If you just press an aluminum pulley on a steel shaft, eventually it will wear out the aluminum pulley and it will become loose on the shaft. They use a steel mandrel that presses on the shaft and then the pulley bolts to the mandrel. I have used them several times and have been extremely pleased with no problems. I can also get them for you. Give me a call if I can help.
Eddie
Young Performance is offline
Old 09-22-2009 | 09:17 AM
Wild's Avatar
Eddie
Ya, get me a price please, i need them in the next few weeks
thanks
Wild is offline
