raw water impeller
Old 09-23-2009 | 03:07 PM
Default raw water impeller
this is probably a dumb question but in which direction should the rubber vanes be flexed during operation? is the vane to flex in the direction of the shaft rotation or away from the shaft rotation. 454 magnum big-block
File Type: pdf
thepannys is offline
Old 09-23-2009 | 03:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Your top picture is correct. Don't worry about getting the vanes oriented correctly when changing the impeller, they will flip to the right direction as soon as the pump is turned.
US1 Fountain is offline
Old 09-23-2009 | 05:00 PM
put a little dish washing sop on the impeller (cheap lube)
topfueleb is offline
Old 09-23-2009 | 05:23 PM
thanks a lot for your help
