Does anyone else do this to winterize their motors? Is it safe?
Last year the guy used the saltwater flushes and wired a bucket to it and filled the bucket with antifreeze and fired the motor. It pulled the antifreeze out of the bucket and through the motor. Is this sufficient?
i have always lived in the country and didn't have neighbors looking however you could always contain the antifreeze with a small plastic childs pool if need be or even use some flexable 4" corigated pipe and clamp it over your tips and into a 5 gallon bucket.
Use RV antifreezze straight and you dont have to worry about spillage. I pull the block, manifold, and cooler petcocks, then run the antifreeze thru it, have a friend help and as soon as the mix comes out the prop or tail pipes -30 be ready with the fogging oil and fog it and shut it down. Dont forget the stabil, drive service, water sep filter and oil change.
Warm the engine to get the thermostat to pop...drian the block quickly...then run it with anti-freeze just like you saw. Been doing it that way since 1994 without issue.
I actualy change all the fluids/filters first but don't use fogging oil with EFI motors. Drive fluid etc changed later that same day so it's ready for the spring.
Foging is very important expecially if using E-10 fuel. Get a 2 gallon fuel tank make a 2 stroke mix with stabil. and plumb it in just before the water sep filter. Run it thru, it wil coat and protect both EFI and carb engines, and there fuel systems. Merc and Volvo both have service bulletins out on the proceedure, the mix is a little different but the 2 stroke 50 to 1with a good synetic oil and stabil will work.
Running AF thru is better than nothing, but you should drain the block before running it thru. You should also still fog the engine, treat the fuel & change the oils..
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
they are the drain plugs with wings on them that you take out or turn to drain the water.. Jamie / Lakeside
