Ignition Options ? >
Ignition Options ?
Ignition Options ?
Old 04-07-2002 | 12:49 PM
Sammy
Default Ignition Options ?
It looks like I need to replace my Thunderbolt V ignition due to the built in rev limiter. It shuts me out after hitting 4900 rpm. I can go with another Thunderbolt system, version IV or an after market unit. I was looking at a Crane system witch has an ajustable rev limiter and a variable curve slection. Another bennifit of the Crane is that I can use my existing distributor. So... give me your thoughts, I would like to make a decision early this week.
THX
Sam
Old 04-07-2002 | 01:25 PM
Smitty's Avatar
I am dealing with the same dilemma as you. Your rev limiter should be kicking in at 5050 rpm. Check your tach against another one or a test meter. You may already be at 5050 rpm. I have supercharged my motor and would like to spin it to 5300 but cannot with the Thunderbolt Five. It also has a knock sensor which I feel is a good thing to have. I am researching replacing the stock module with one from a hp500. I called Mercury Racing and they said it should work just that the curve would be different and it does move limiter to 5300. All I need to do is get to my boat and pull old module out for comparison. I will post here if my attempt is successful.
Dave
Smitty is offline
Old 04-07-2002 | 02:20 PM
Lee's Avatar
Lee
Sam, Good to hear you got your boat back, I have heard good things about the Crane system, but have no actual experience with the add on set up your looking at.
Bigwavz, I supercharged a 1997 454Mag carb with T-Bolt V and Knock sensor and I used a Merc 525sc ignition module and it worked great.
By the way I still have the 525sc module if you are interested.
Lee is offline
Old 04-07-2002 | 03:09 PM
Sammy
Lee, would that module let me get around the rev limiter that I currently have.
Sam
Old 04-09-2002 | 06:45 PM
Lee's Avatar
Lee
Sam, It would not work too good in a non supercharged application because of the limited amount of advance in the module.
Lee is offline
Old 04-09-2002 | 08:46 PM
Cignificant's Avatar
I just installed two of the Crane 7Ms on my Cig - I had absolutely no problems. You'll need someplace to mount them, and you'll need to modify your distributors, but they work great. If you have any questions let me know..
Cignificant is offline
Old 04-09-2002 | 08:57 PM
Sammy
Actually I am going to change out the TB V for a IV this week. Thanks for the reply Lee.
Sam
CAPTAIN CHUCK
0
06-30-2007 04:29 PM
glassdave
General Racing Discussion
8
05-06-2007 10:39 AM
MadMat
12-18-2003 04:08 AM
wwwTOPDJcom
10
04-03-2003 06:00 PM
