bravo to xr swap ? >
bravo to xr swap ?
bravo to xr swap ?
Old 09-26-2009 | 06:52 PM
Default bravo to xr swap ?
Will the xr drive slide rite into my bravo gimbal housing with out changing anything else like the trim rams or anything.
rssteiny is offline
Old 09-26-2009 | 07:45 PM
CB-BLR's Avatar
Chris
Yes
CB-BLR is offline
Old 09-26-2009 | 09:12 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by CB-BLR
Yes
Well...except for the gimbal bearing. The XR bearings aren't as thick leaving room for an XR's larger u-joints. You will need to replace the gimbal bearing......but that's an easy $100 part you can do yourself.
t500hps is offline
Old 09-26-2009 | 09:59 PM
You need to replace the gimbal bearing and put spacers in the trim rams. Mercury sells a kit with all the parts needed with instuctions. I got mine from BAM. Jeff Wurl
jwurl is offline
Old 09-27-2009 | 02:05 AM
Correct.
Griff is offline
Old 09-27-2009 | 08:19 AM
Thanks guys, is the xrs worth the extra money to hold up with 650 plus hp.
rssteiny is offline
Old 09-27-2009 | 08:32 AM
A regular bravo wont take 650 hp for long so it's worth a try.
Pismo10 is offline
Old 09-27-2009 | 11:07 AM
monstaaa's Avatar
the bravo will last quite longer than most think with more than 750 hp. it is the accelerating and miss throttling that kills them. brickin it out of the hole and holding it down while at speed in sloppy and ruff water will wipem out.
i have set up a conciderable amount of bravo 700-950 hp set ups. change oil every 10 hrs. eas ythrottling and moderate planing and accelerating will last you. and yes a decent while longer than a stock bravo.
monstaaa is offline
Old 09-27-2009 | 09:09 PM
nordic95's Avatar
I wouldnt do it again.I also changed over to XR when I built my 600hp and in two years both upper gears sets have blown. Everyone tells me merc had bad gears and that the new ones should be ok now.Well after 3200.00 just for gears and about 400.00 for bearings later and now I am thinking of going back to my spare bravo ones to gain the speed I lost between the different drives.
Nordic95
nordic95 is offline
Old 09-27-2009 | 09:42 PM
I did loose 4 mph when i switched to the XR. Jeff Wurl
jwurl is offline
