"Boat Float" boat lift system....
2002 Boat Float system. New pump last year but it does need some TLC. most likely will need the rams re-built (kit is under 500 from boatfloat). Bunks have been modified to fit twin step Top Gun (need new carpet).
This float has been used to hoist a 42 Tiger and a 38 Top Gun. Will handle anything around or under that size rand with out issue.
Currently located in Southern California but can arrange for shipping.
Asking best offer and will entertain trade offers.
Here's info on Boat Float system from the website:
BoatFloat® is a floating hydraulic boatlift that will provide you with enormous flexibility and benefits, such as:
Portability – because BoatFloat is a portable boatlift it is welcome at marinas, condos and yacht clubs. Also, BoatFloat can be upsized to handle any new or larger vessels you might purchase down the road.
Ease of use – BoatFloat is powered by an ordinary garden hose and 15-ampere, 110 volt electricity available at marinas and water communities everywhere. Our unique, patented hydraulic boatlift provides a fast, constant level lift. With the push of just one button on your BoatFloat remote control, you will have your boat out of the water.
Appearance – BoatFloat has a low profile, it does not block waterfront views. The floating boatlift has a stealth-like appearance.
Flexibility – BoatFloat accommodates all boats weighing up to 30,000 pounds. Our portable boatlift is ideal for salt and fresh water use, remains stable in rough water conditions and is virtually maintenance free.
Installation – No permits are required for installation and our floating boatlift is easily secured with simple dock lines. Your BoatFloat can be delivered and installed very quickly.
