Block heaters vs winterizing? >
Old 10-04-2009 | 09:38 AM
Default Block heaters vs winterizing?
Saw these block heaters on Rex marine and was curious if anyone uses block heaters in stea of winterizing the motors... Searched the threads and hadn't seen any earlier convos on it
FuelinAround is offline
Old 10-04-2009 | 09:55 AM
I guy here in town used one. Worked good until the power went out. Not worth the chance to me. I guess depends on your location.
redbud35 is offline
Old 10-04-2009 | 10:03 AM
hoozeyurdaddy's Avatar
to many what if's with block heaters, when winterized properly you don't have to loose sleep at night wondering if the heater is working. put antifreeze in it you'll sleep better.
hoozeyurdaddy is offline
Old 10-04-2009 | 10:11 AM
winterizing involves more than the block.don,t forget your exhaust manifolds,or headers,oil&powersteering coolers,waterpump&all residual pluming.also,antyfreeze does not need a continus power source.
mike tkach is offline
Old 10-04-2009 | 01:17 PM
outriggers's Avatar
Even with anti-freeze, at the first real cold spell at about 10 degrees I wonder how good of a job I did. Doug
outriggers is offline
Old 10-04-2009 | 01:59 PM
Throttle Fever's Avatar
Thumbs up 10-4
I am with Mike. Its more than the block your winterizing.....
Throttle Fever is offline
Old 10-04-2009 | 04:52 PM
Agreed.... I just had never heard of any reviews on them...I only plan on stopping my winterizing when my new heated shop with back up generator is done next year... I will save that either $500 to pay someone or $75 to do it myself to pour into some mods and tuning every winter
Old 10-04-2009 | 05:34 PM
Rookie's Avatar
did you say $500 to winterize????
Rookie is offline
Old 10-04-2009 | 05:47 PM
2 motor Blocks, toilet, sink, oil change, drive inspection.... They run close to that locally
Old 10-04-2009 | 05:53 PM
anti freeze also is a rust inhibitor. you don't your blocks rotten away
38tg is offline
