Is this prop work worth the quan $$ HELP! >
Old 10-07-2009 | 02:28 PM
Default Is this prop work worth the quan $$ HELP!
Heres the gig.. 312 fastech,twin 454mag mpi, 28p bravo 1's.
great hole shot can even pop up 2-tubers fast. Boat runs 70mph but is bouncing on the rev limiters.. I can tell she wants to go more... I know first off re-map ECM bump rev limiters to 5400 or so+ some extra yummies...
Is it worth the bucks $$$$ to change the pitch up one and pocket blades or even thin leading edge. Or am I waisting money.. I have not put my EMI offshores with S/S risers on yet will do this winter along with Vortch Breathers.....
give your thoughts ole' boating buddies.
Give me fuel- Give me fire-Give me that which I desire.
silent lucidity is offline
Old 10-07-2009 | 08:50 PM
PAST DUE's Avatar
what year is your 312 ? and what gear ratio are you running. i would talk to Brett @bblades he can tell you the right thing to do as far as props are concerned he labbed a set for me and the boat has never run better.
PAST DUE is offline
Old 10-08-2009 | 09:55 AM
Default prop
My is a 1997 312..Fastech. 203hrs now. What did he do for you and what results did you see..? Thanks
Old 10-08-2009 | 07:19 PM
PAST DUE's Avatar
he labbed a set of 28p bravo 1's i am running 1:36 raitio drives with imco 2 in shorties with whipple side mount super chargers before i sent him the props i was running on average 83mph on gps during the middle of the summer turning about 5150 rpms after Brett did his magic i now run an average of 86 mph all summer and have seen 89 mph a couple of times lightley loaded on the revlimiters hard @5400.
PAST DUE is offline
