Merc Hipo gear lube VS. Amsoil severe gear 75W-110
I know there are a lot of threads about gear lubes but am curious who switched from the Merc gear lube to Amsoil, why, and how the results have been? I have new XR outdrives on my boat, and after 40 hours of use, we just changed the fluid and it has a burnt smell to it. no metal flakes in the oil and it still has the green color to it but am concerned if I am getting the best protection I can for it. Expensive oil is still a lot cheaper than a rebuild or a new drive. Would my drives benefit from going to amsoil? I have read some reviews and amsoil seems to rate higher but would like some feedback from members who switched and what your opinions are on it. Thanks!
I use the AMSOIL Synthetic Marine Gear Lube SAE 75W/80W-90 with very good luck running a full season (80 hrs) without changing the oil. The outdrive oil gets very hot and I think the synthetics hold up better to the heat. I have Bravo X drives and I've heard that usually the Amsoil is used in higher HP applications but as you said, the oil is cheap compared to repairs.
We are also an Amsoil dealer and have had great succes with there Marine gear lube.
http://www.amsoil.com/redirect.cgi?z...551&page=index
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
Charter Member #40
I run Amsoil in some #5's. Put 200 hrs on them, after several poker runs etc. We normally do the runs at 70+ so there is ample opportunity to put some load on the components. TNT found nothing wrong internally, nothing needed replacement. We did some lowere bearings as a preventive step as well as reversing some gears. I am sold on the stuff!
I use Merc Hi Perf. Keep in mind the stuff stinks new.. I've made several drive oil changes to my drive w 165 hrs. Remenber your warranty if merc. sniffs out the Amsoil they might void your warranty if you need to fall back on it. I've lived this down w/ auto warrantys and they look for any reason to void if possible... Although Amsoil Kicks Ase My 2 cents...
