rebuild 502 mag heads?? >
Old 10-09-2009 | 12:18 PM
Default rebuild 502 mag heads??
ok, if I pull heads out to have rebuilt and have rollers installed what type h.p. gains can I expect? Also is there any way to replace cam without pulling engine out to have the room on 27 fever? I already have stainless marine mainifolds on and seeking maybe 50-75 more h.p. any suggestions race fans?
ricric is offline
Old 10-09-2009 | 01:41 PM
Probably about 30 Hp for the cam change. A fresh valve job may regain some lost HP, but it won't add anything without some port work. Mill the heads .030 and up your compression to about 9:1 and gain maybe another 10hp.
Griff is offline
Old 10-11-2009 | 06:57 PM
what if i had the rollers installed on the heads and port/polish work what do you think I can gain h.p. would i be better switching to new dart performance heads? would this require additional mods?
ricric is offline
Old 10-11-2009 | 07:30 PM
obnoxus's Avatar
Charter Member #1171
alum heads are your best bet,,,, plus you eliminate the exhaust seat issue of the cast heads with the new oxygenated fuels.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 10-12-2009 | 07:21 PM
dart pro1 marine 325 heads the best set? and are there any special mods to adapt to stock 502 mag (1997 fountain). thanks for any help..
ricric is offline
