drive-line vs. plug in? >
Old 10-09-2009 | 03:39 PM
dkwestern's Avatar
Default drive-line vs. plug in?
Whats the difference?
dkwestern is offline
Old 10-09-2009 | 04:07 PM
Sean H's Avatar
A to Z
one has a driveshaft to the transom assembly, the other "plugs in".
Sean H is offline
Old 10-10-2009 | 01:06 PM
dkwestern's Avatar
OK so a stagger front engine is always a driveshaft.
Doesnt the driveshaft "plug in" to the transom assembly?
I ask because it seems transom assemblies have diff. styles?
Old 10-10-2009 | 02:05 PM
Sean H's Avatar
A to Z
the driveshaft doesn't plug in, it bolts to a flange style transom assebly. A plug in style transom assembly accepts a splined shaft.
Sean H is offline
Old 10-10-2009 | 05:00 PM
Mbam's Avatar
Offshoreonly Advertiser
If it is a Bravo, transoms are the same, an additional bearing support/shaft hooks up to the driveline (if it is a driveline application).
#6 has differant transom assemblies, the driveline style includes the bearing/shaft. The plug in requires the #6 tailstock on the transmission.
Yes, the front engine on a stagger requires a driveline.
Mbam is offline
Old 10-11-2009 | 03:48 PM
dkwestern's Avatar
Thanks!
