Jacking up torsion axles
Old 10-10-2009 | 06:06 PM
sleek1's Avatar
Default Jacking up torsion axles
I have a triple axle aluminum trailer with a Fastech 353 on it. I want to repack all the axle bearings this winter. My problem is that my floor jack won't fit on the torsion part of the axle. I'm told a bottle jack is too wide (will hit tire and not make contact with torsion axle). What do you DIY use? I'd prefer to keep the boat on the trailer when I do the bearings.
sleek1 is offline
Old 10-10-2009 | 08:27 PM
DM
Would something like this work?
DM is offline
Old 10-10-2009 | 10:28 PM
c_deezy's Avatar
Depends on the trailer. Here is how I did it:
c_deezy is offline
Old 10-10-2009 | 10:49 PM
sleek1's Avatar
DM
I thought about that set up. I was hoping to get all three tires on one side in the air at the same time. That way I can get all the bearings cleaned and greased at the same time.
sleek1 is offline
Old 10-11-2009 | 12:43 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I am able to get a bottle jack RIGHT behind the tire and catch the back of the spindle holder (drop part of the torsion axle). I've made this work on my last three trailers.
Sydwayz is offline
Old 10-11-2009 | 08:37 AM
obnoxus's Avatar
Charter Member #1171
Not with torsion axles,,,, just the one tire would go up
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 10-11-2009 | 08:47 AM
sleek1's Avatar
Thanks for the replies. Sydwayz I was hoping you would shed a little wisdom on the subject. I'll look for a bottle jack.
sleek1 is offline
Old 10-11-2009 | 08:00 PM
bowtie's Avatar
Actually that setup is for torsion axles. The trailer manufacturers tell you not to jack them up but to run a wheel up on a 6x6. You're not going to get all 3 wheels off of the ground at one time that way though.
bowtie is offline
Old 10-12-2009 | 01:34 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That said, its more difficult to do on my Myco. I have one my trailer toolboxes full of 2x6s to build ramps with; as well as carrying a bottle jack.
Sydwayz is offline
Old 10-13-2009 | 11:12 AM
sleek1's Avatar
So you guys are telling me you change one bearing/wheel at a time? You never have all three tires off the ground at once?
sleek1 is offline
