Lift Size for 38 Special
knotbad,
I weighted my a few years ago...full tank of gas, water tanks full, coolers,tools and everything we always have on board.This is with an aluninum trailer, so I would say 12000lbs lift would be fine.
Do you have a cable lift or a hydrohoist type lift? If it is a cable lift you can probably go with bigger cable (call the manufacturer) it is a pretty cheap upgrade. If it is a hydrohoist or similar, You might have to put the boat away with less than a 1/2 tank every time you put her up... I had a 8K lift and it struggled with my 30, then I got a 342 and it left the belly in the water so I added a 12 foot tank under the middle and it worked great.
The lifts are actually tested for more than there rating too, I would think you would be fine with a 12,000 but as Redbud said, a 14,000 may be easier and less expensive to find.
12k min,,,,,, 14k is preferable,,,,,,plus that gives you room to upgrade !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
