Quick Help With Prop Needed >
Old 04-08-2002 | 05:07 PM
Baja232's Avatar
Default Quick Help With Prop Needed
How do you measure the 'spline' size of a prop?
I'm selling a used Quicksilver Mirage 19p prop and someone asked me the spline size. I have no idea what it is as I bought the prop used myself, and it just fit right on the prop shaft of my Bravo 1.
The prop numbers are (48 13700 A41 19P) if that helps.
thank you
Baja232 is offline
Old 04-08-2002 | 07:12 PM
It fit on the bravo drive ? Count the number of splines carefully . I can't remeber but I think it is like 14 or 15 splines on a bravo . To messure spline size you need something to acurately messure how thick the shaft is where the spline are . Usualy smaller then the actual prop shaft size .
Some one must know ,come on help the guy out ! It's not like this is the only bravo out there !
boot is offline
jeff1000man
02-11-2007 11:19 AM
spitfire1
08-24-2005 09:15 AM
Sydwayz
12-16-2004 06:41 PM
SummerObsession
8
05-13-2004 02:27 PM
Tim G.
02-06-2003 04:13 PM
