Get into hatch with dead battery >
Old 10-13-2009 | 07:22 AM
Default Get into hatch with dead battery
I haven't been out to the marina in a while where I keep my 260. It was inaccessible for a few weeks due to flooding, now it is getting cold and usually raining when I have time (weekends). So I am concerned the two batteries have died and I cannot get into the hatch. The two batteries are hooked to a Perko switch that is accessible.
So my dumb question of the week is how do you get the hatch open when the batteries are dead on a (1999) 260?
cfo20 is offline
Old 10-13-2009 | 07:39 AM
Cfo,
on my 260, i can lift my hatch manually from the front with out turning my batteries on.. and use a pole ot hold it up if u have to..
hope this helps
q
qaberdeen is offline
Old 10-13-2009 | 08:35 AM
This is a pain
Early on my manufactuerer cut out 2 holes behind the seat back so you can pull the hatch pins if needed- later model have a molded plug to charge through the back if needed.
Or You could trickle through a 12v socket.
Worst comes to worst take the hatch off from the back. Before I did that I'd try to trickle through anywhere before that.
UD
Uncle Dave is offline
Old 10-13-2009 | 09:18 AM
jumper cables through the accesible perko switch. Should give you enough o get the hatch up.
jeff1000man is offline
Old 10-13-2009 | 10:17 AM
sl
Velocity usually has a small swing plate mounted to the lift arm/hatch bracket. It allows you to lift the hatch up about 3-4" without any power. You then should be able to access the quick release pin from the bracket and manually lift the hatch. It's heavy but one person should be able to lift the hatch.
sl is offline
Old 10-13-2009 | 02:03 PM
If your hatch actulator is located in the back of the motor, u should be able to lift it up without any power, i can lift mine atleast 2-3ft without releasing the pin..hers a pic of mine
Old 10-13-2009 | 02:18 PM
As said, trickle or booster pack. Attach pos and neg from booster to as large as you can find wires under dash. Worked for me yesterday, was a dumb a$$ and left the tunes on.
Andy is offline
Old 10-13-2009 | 05:12 PM
Oh Deere's Avatar
My 2000 260 could be lifted without power...the previously mentioned swing plate.
Oh Deere is offline
Old 10-14-2009 | 07:17 AM
I do recall the swing plate on the hatch. I didn't even think about the function of it? Once it stops raining here, I will have a chance to go out and check on it. Thanks everyone for the info!
cfo20 is offline
Old 10-14-2009 | 07:30 AM
cfo, if you need a hand, let me know! I am right around the corner from you. Be more than happy to help!!
DKerns is offline
