Help!
Old 10-27-2009 | 11:18 AM
Default Help!
I have a 1988 Pachanga 32. Went to take the batteries out of her yesterday and the starboard side batteries appear to be dead - can't open the hatch to get to the engine compartment - UGH! Can't figure out how to manually open the hatch - has to be a way - anyone know? Thanks
Riverqueen is offline
Old 10-27-2009 | 11:45 AM
McGary911's Avatar
you have a battery switch outside of the engine compartment? If so, you can pull that, and hook up another battery through those terminals. Just enough to get the hatch motor to run.
Once you get in, you can install a couple of battery lugs somewhere outside the engine bay for next time. Something like this: http://www.summitracing.com/parts/PRF-40106/
Good luck.
McGary911 is offline
Old 10-27-2009 | 11:58 AM
Thanks very much - there are 2 large on/off knobs for the batteries outside the compartment - do you just pull them off??
Old 10-27-2009 | 01:37 PM
Just run a power wire from a good battery to the back of the hatch switch.
Griff is offline
Old 10-27-2009 | 01:57 PM
What does a pachanga look like ?
mike
thedonz is offline
Old 10-27-2009 | 03:07 PM
McGary911's Avatar
http://www.theyachtmarket.com/boats_for_sale/6734/
nice classic lines.
Old 10-27-2009 | 03:25 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My Pachanga had an access cover in the rear seat storage that would allow me to reach the hatch ram lower mount and pull the pin out.
US1 Fountain is offline
Old 10-27-2009 | 10:29 PM
Or many times you can back feed through a cig lighter. Many of the "emergency jumper" kits have a cord that lets you do that. You can supply enough power to get the hatch open with them.
paulb32 is offline
Old 10-28-2009 | 10:35 AM
You can also hook a battery up to the main power/ground wires under your dash on the fuse panel to get power to it. I've had to do that a few times, I used a jumper box.
Brandon is offline
Old 10-28-2009 | 12:02 PM
J.B. Marshall's Avatar
JB Marshall
They were hot looking boats when that model came into the market, not many around.
J.B. Marshall is offline
