engine oil temperature?
Old 10-28-2009 | 11:23 AM
Default engine oil temperature?
What is the proper running engine oil temperature? thanks, Joe
joepequa is offline
Old 10-28-2009 | 12:07 PM
Default 300
300
joepequa is offline
Old 10-28-2009 | 12:18 PM
2112's Avatar
Thats hot.
212 minimum 260 hot after hard runs are my goal temps.
2112 is offline
Old 10-28-2009 | 12:19 PM
bcfountain's Avatar
Registered User
Default oil temp
your oil temp should be over 215 ,to cook-off condensation,and the high end should never see 285.mine runs around 245
bcfountain is offline
Old 10-28-2009 | 12:23 PM
At least 212* during a normal cruise to burn off any condensation and a max of around 260* after a WOT run. These are good numbers to shoot for.
300* is too hot.
Griff is offline
Old 10-28-2009 | 12:26 PM
300 is to HOT.
FIRST AFENCE is offline
Old 10-28-2009 | 04:42 PM
blue thunder's Avatar
180f on the guage. It will be higher than that where unmeasured and boil off water. This number gives you room for hard long runs without running into 260f which is the highest acceptable for short periods. Starting with a cruise temp of 212f doesn't leave a lot of room for hard running. My .02 on the subject.
BTW my gauge reads about 150f on a long cruise and no more than 180f after a 50 mile hard run. No condensation issues at all although I can tell it is close by.
blue thunder is offline
Old 10-28-2009 | 07:26 PM
X2 that is how mine runs, heck after a good long wot run I don't like to see it go over 190f
26 REDLINE is offline
Old 10-28-2009 | 08:11 PM
GLH's Avatar
GLH
All the motors we have for the MTI have dry sumps and the most temp I have seen through the whole summer is around 150*.
GLH is offline
Old 10-29-2009 | 01:13 AM
You also need to take readings from the oil pan where the oil is the hottest.
Griff is offline
