Go Back  Offshoreonly.com > Owners Forum > Powerquest
1993 290 enticer >
1993 290 enticer
1993 290 enticer
Old 10-29-2009 | 10:55 AM
Default 1993 290 enticer
Does anybody know if PQ put 502efi's in the 93 290 enticer?
I am in the process of buying this boat and the owner said the boat was built for one of the VP's @ PQ and it has 502efi's in it. Is there a way I can research who had this boat first?
DrWatts is offline
Old 10-29-2009 | 04:19 PM
jmackin's Avatar
my buddy had one with 502's. What color? where is it?
jmackin is offline
Old 10-29-2009 | 04:38 PM
Lake of the ozarks and its orange yellow and purple trible flames real nice paint it came frome lake Perry in Kansas
DrWatts is offline
Old 10-29-2009 | 06:46 PM
I had a 93 with 502s. The boat was GREAT. That is the only power package I would look for if you want to go fast without having to keep it full throttle. You can cruise all day at 55-60 and not drain the fuel tank super fast.
specialk is offline
Old 10-30-2009 | 05:45 AM
specialK, do you rember what props you where running this boat has 3 blade 22p? it needs more Pitch cavs real bad coming out of the hole and top speed is aboat 55 to 60.
DrWatts is offline
Old 10-30-2009 | 07:22 AM
22p 3 blade dont think is a merc prop.
you should do pretty good with a set of 25 pitch Mirage Plus spinning out ,that should put you in the 70s
boatnt is offline
Old 10-30-2009 | 05:57 PM
I ran 23 mirage 3 blades. Used the same prop without ever having them worked for 10 years. I never used gps on the boat. Speedo went to 75 and it would bury it without having it trimmed out all the way. Dont ask how fast that really was, but I think it was an honest 74-75 mph hour boat. If i remember correct, 3500 rpm would be at or over 60. The boat would get on plane super easy, never a cavitation. Max rpm would be about 5100. If the one you are looking at will only hit 60, I would hope you are hitting the rev limiters at 3/4 throttle because there should be a lot more to go. Hopefully it is only a prop issue and nothing mechanical.
specialk is offline
Old 10-31-2009 | 01:07 PM
I've got a 91 with 502 carbs and I am running 23 Mirage props and on GPS I am seeing 70-72 at WOT. I have never tried any other size props.
skoboat is offline
Old 11-02-2009 | 12:40 PM
thank you
Thanks for all the help, I am going out this weekend and taking it out for a test ride. I will be looking for what position the throttles are at when it tachs out. hope to see some of you (IL. IN.) on lake mich. next year.
DrWatts is offline
Old 01-15-2010 | 09:57 PM
wondering if this boat is still on the market?
BERUBE is offline
