Short Section S/S Pipe >
Old 10-29-2009 | 09:08 PM
CcanDo's Avatar
Default Short Section S/S Pipe
Needed, 4.0625 - 4.125" ID x 2' /+ section of Seemless Stainless Steel pipe. The wall thickness can be 3/16" or thicker.
CcanDo is offline
Old 11-01-2009 | 09:03 AM
Smitty's Avatar
Here is where I get my stainless exhaust pipe from.
http://www.stainless-specialties.com/products2a.htm
Smitty is offline
Old 11-01-2009 | 09:35 AM
Ptufaro's Avatar
I have a length that I bought a while ago but I don't remember what size it was exactly. I will check on monday and take a pic.
Is it correct that you only need a 2" section?
Ptufaro is offline
Old 11-01-2009 | 12:38 PM
CcanDo's Avatar
No, I need a section ABOUT 2 feet long. It can be a couple of inches shorter. 4 1/16 or 4 1/8 inches, Inside Diameter, with a 3/16 or 1/4 inch wall thickness, Stainless Steel round pipe.
The material will be used for a prototype.
CcanDo is offline
Old 11-03-2009 | 09:32 PM
Ptufaro's Avatar
I measured the wall thickness of the pipe I have and it is only 1/8". Don't seem like what I have will work for you, but if it will let me know. Did not measure the diameter but I can if the 1/8" wall thickness will work. (diameter is around 4")
Attached Thumbnails Short Section S/S Pipe-pipe.jpg   Short Section S/S Pipe-pipe-2.jpg
Ptufaro is offline
Old 11-04-2009 | 05:59 AM
Mbam's Avatar
Offshoreonly Advertiser
I think the closest you will find is sched 10 or sched 40 stainless pipe.
That's an odd size you are looking for.
See if this helps:
http://www.mcmaster.com/#stainless-steel-pipe-fittings-and-pipe/=4csm2r
Mbam is offline
Old 11-05-2009 | 06:24 PM
CcanDo's Avatar
Thanks for your help, also thanks Marc, a section is on it's way.
The refineries use it in some of their fabricating.
CcanDo is offline
Old 11-06-2009 | 03:46 AM
Just for kicks tube is seamless pipe is generally seamed
I'CE is offline
