Pickups - Thru-hull or Transom mount??? >
Old 10-30-2009 | 01:30 PM
CB-BLR's Avatar
Chris
Default Pickups - Thru-hull or Transom mount???
I have the motor out of my 28' Nordic Heat for some upgrades, and need to install a water pickup for my innercooler.
The boat is a v-bottom with a single step, and a notched transom. It also has a small pad that extends about 6 ft forward in a v-pattern, with the widest part of the pad being about 8 inches wide at the rear. I will not be putting the pickup in the notch area so as to not disturb water flow to the prop. I would like to install the pickup outside the prop diameter area for the same reason... unless I go thru hull, and mount it about 2 ft forward of the notch, on the pad or to the side of it.
It needs to be AN-12, and will have a seperate sea-strainer.
Do you think going thru the hull, or doing an adjustable transom mount pickup would be faster??
Thanks in advance,
Chris
CB-BLR is offline
Old 10-30-2009 | 03:12 PM
X2 on this question! I have a 25' sxt cat, and the intercooler
is teed into the sea water outlet, which to me seems like way
too much water press.- especially at idle- shoots out the discharge port(-8) about 5'. was going to put a water press
relief valve(left over jetboat part) and another dump, but the
pickup idea sounds better!
blownjet 468 is offline
