Questions For Cooling And Steering >
Old 04-09-2002 | 06:03 PM
30FORFUN
Default Questions For Cooling And Steering
I WAS TOLD I NEED TO INSTALL AN EXTERNAL WATER PICKUP BECAUSE THE DRIVE WONT SUPPLY ENOUGH WATER TO THE NEW MOTOR A PROCHARGED 572. IF I DO NEED IT WHERE DO I PUT IT AND WHAT DO YOU DO WITH THE EXISTING DRIVE COOLING HOSE AND INTAKES. WHICH EXTERNAL STEERING UNITS DO YOU GUYS PREFER IN SALT WATER AND ARE THERE ANY GOOD DEALS OUT THERE FOR SINGLE/ DUAL RAM ASSIST UNITS . THANKS BRYON
Old 04-09-2002 | 06:20 PM
I bought my IMCO steering system from Teague Custom Marine. the price was less than buying direct and the kit was very complete. I'm using it in fresh water but it was designed for salt. It's a very good product.
JohnJan is offline
Old 04-09-2002 | 06:40 PM
Tinkerer's Avatar
Thumbs down
The BRAVO / BBC seawater pump is probably big enough to feed 2 engines since most of the water is being bypassed into the exhaust to quiet it. The only reason for needing an external water pick up is if your water inlets don't collect enough water. Then all you need to do is put on a nose cone with low water pick up.
Tinkerer is offline
UNSANE
5
06-20-2007 06:43 AM
David Stotz
10
11-14-2006 12:32 AM
rchevelle71
4
11-29-2004 08:45 AM
rchevelle71
11-27-2004 11:50 PM
bouncedcheque
2
11-10-2004 01:03 PM
