How do you tell if a 454 is a mag or not?
The intake manifold is raised higher towards the carb ,where a 330 oval port has a more flatter intake manifold,if parts (manifolds )has been swapped on engines its difficult to say ,but there is a way to see if the heads are retangular or oval port , on the end (front/rear side ) of each magnum/retangular cilinderhead there is a bump in the castingline ,all steel retangular port heads have these ,,bump,, where the ovals have a flat castingline ,see if you can find a magnum head ,and look for the bump you,ll see what I mean .
There probably is a designated letter or number, or combination of such, that would determine whether it is a Mag or not. However I don't know what it is. If you give the number to a dealer they will be able to tell you. You may even be able to look it up on-line.
