Anyone know the torque ratings on the following engines? 350mg/7.4L/454mag >
Old 11-02-2009 | 10:26 PM
Default Anyone know the torque ratings on the following engines? 350mg/7.4L/454mag
I was wondering if anyone knows the factory torque ratings on the following engines?
350 magnum 270hp
7.4l 330hp
454 magnum 365hp
Thanks for your help!
twistedvelocity is offline
Old 11-04-2009 | 01:17 AM
anyone?
Old 11-04-2009 | 12:38 PM
The equation for horsepower is HP = (Torque X RPM)/5,252
Therefore ----> Torque = (HP X 5252)/RPM
So you need to know at what RPM the factory HP ratings apply. Let's assume for the 454 mag it is 4900 RPM (I have no idea...)
Torque = (365 HP X 5252)/4900 = 391 lbs*ft
This isn't peak toque over the RPM range, just the torque at this HP rating point.
This equation shows why every dyno sheet has the HP and Torque curves crossing at 5252 RPM.
4mulafastech is offline
Old 11-04-2009 | 09:53 PM
Thanks thats good info period.
I figured someone would know the specs.
Old 11-05-2009 | 07:36 AM
C_Spray's Avatar
Diamond Member #001
Remember that those engines are all propshaft-rated, so they actually make about 10-15% more hp at the crank. I would guess that peak power would be around 4400-4600, but peak torque would be at a lower rpm than that, probably 4000 +/- 200 rpm.
C_Spray is offline
