stainless marine exhuast manifolds  what valve covers are you using with BBC ? >
Old 11-04-2009 | 06:01 PM
Default stainless marine exhuast manifolds what valve covers are you using with BBC ?
I went to mock up the stainless marine exhaust manifolds today and they hit the valve covers
I tried them with two different styles of covers
1 set was edelbrock elite series valve covers
the other set was a regular tall style cast aluminum covers which were shorter in height than the edelbrocks,
and the manifolds hit with either set
so guys that are using these exhaust manifolds what type of valve covers are you using ??
I have my stock set of covers still but they are not tall enough to clear the roller rockers
thanks
cbellamore is offline
Old 11-04-2009 | 06:11 PM
Rookie's Avatar
Merc 425 valve covers.
Rookie is offline
Old 11-04-2009 | 06:27 PM
Merc Hp500's
Attached Thumbnails stainless marine exhuast manifolds  what valve covers are you using with BBC ?-s7300096.jpg
formula 382 sr-1 is offline
Old 11-04-2009 | 06:31 PM
Not sure what these are, they came with the old engines.
Attached Thumbnails stainless marine exhuast manifolds  what valve covers are you using with BBC ?-dsc03884%2520%2528small%2529.jpg   stainless marine exhuast manifolds  what valve covers are you using with BBC ?-motors2.jpg
TexomaPowerboater is offline
Old 11-04-2009 | 06:36 PM
These are real nice and a great price... I'm running them with a Eddie marine long stainless risers exhaust system
http://cgi.ebay.com/ebaymotors/BIG-B...item45ef099940
http://cgi.ebay.com/ebaymotors/BIG-B...item45ef099aa8
Rockfish71 is offline
Old 11-04-2009 | 07:13 PM
bcfountain's Avatar
Registered User
Default valve covers
i use imco valve covers.i have had them on two diffrent motors and i can remove the covers without removing the exhaust.i use a 1/4 " drive with flex-shaft extion,about10".the stainless marine were easyer to get to versus the emi,s,but doable.
bcfountain is offline
Old 11-05-2009 | 03:53 AM
when we did mine i used the stockers. just used two cork gaskets sealed together for clearence . works fine. mark
mookymonkey is offline
Old 11-05-2009 | 05:18 AM
I have 2 sets of the same covers that Rookie has in post #2 for sale if your interested.
kreed is offline
Old 11-05-2009 | 01:19 PM
Rookie's Avatar
I also can remove my valve covers without removing my exhaust manifolds. I just use stainless 1/4-20 socket head cap screws and a 6"-8" ball end Allen wrench.
Rookie is offline
Old 11-05-2009 | 03:13 PM
Eddie Marine for me. They are great with the socket cap screw. Nice valve covers!
FasterPlease is offline
