496 mag to 496 mag HO conversion >
Old 11-07-2009 | 04:47 PM
Default 496 mag to 496 mag HO conversion
I know the only differnce is the ecm program and camshaft.
has anybody done it? worth it?
for less then 2k I could add 100hp to my twin engine boat and go from 75mph gps to 81 mph gps.
I like to hear back from someone that has done it
thanks
boatnt is offline
Old 11-07-2009 | 05:30 PM
I have the cam and ecu if you want to do it. PM me. Both are brand new
Irishtornado is offline
Old 11-07-2009 | 07:38 PM
Velocity Vector's Avatar
Crazy Energy
I don't think I would mess with just a cam. I would go ahead a Raylar it up and you will be more happy. My thinking is you won't be happy with a 100 hp, it will make you want more.
http://www.raylarengine.com/packages.html
Velocity Vector is offline
Old 03-02-2010 | 08:37 PM
whippetde51's Avatar
how much for the cam and ecu?
whippetde51 is offline
Old 03-03-2010 | 07:39 AM
26sonic's Avatar
do a search raylar has a kit , more aggressive cam and ecu reprog. that will bring you up to 460hp instead of 425hp.
26sonic is offline
Old 03-03-2010 | 02:25 PM
A gain of 50hp to each engine will not get you a 6 mph gain. More like 2-4 mph.
You should gain about 300rpms.
Griff is offline
Old 03-03-2010 | 04:42 PM
all that work on twins for 2 mph gain will suck,but if I gain 4mph it would be ok,well I will be doing the cam and ecu switch Saturday,then will have to wait for the 1st nice weekend to see if it was worth it or not.
boatnt is offline
Old 03-03-2010 | 11:36 PM
Throttle body has some mod also I recall...
Back4More is offline
Old 03-04-2010 | 01:45 AM
Just plug all your numbers into the propslip calculator and then increase the rpm by 300 and see what you get. That should be pretty close.
http://go-fast.com/Prop_Slip_Calculator.htm
Griff is offline
Old 03-04-2010 | 02:17 AM
thanks
Problem is that it's a ton of work for very little gain.
You'll need parts obviously.
Even the balancer has to come off. Lot of work but hey I remember all that.
SDFever is offline
