head swap ?
Old 11-08-2009 | 09:16 AM
Default head swap ?
how much difference is there between 502 mag heads and hp500s both carb motors looking to sell my 500 heads to a freing but want to make sure there will be a gain for him.
brians fever is offline
Old 11-08-2009 | 12:23 PM
If they are both Gen VI heads, then they should be the same casting (088, I think). The 500 heads will have rocker studs and roller rockers and the 502 Mag heads have a non-adjustble valvetrain with stamped steel rockers.
Eddie
Young Performance is offline
Old 11-08-2009 | 04:58 PM
Valve size the same? I thought the HP500's had 2.25 vs 2.19?
BadDog is offline
Old 11-08-2009 | 08:08 PM
I think that is correct as well as what Eddie said.
Griff is offline
Old 11-09-2009 | 07:03 AM
thanks guys the castings are the same but the valves are bigger and they are a better valve.
Old 11-09-2009 | 07:06 AM
Rookie's Avatar
I don't believe there would be a noticeable enough gain to warrant the change. Let alone the expense of new head gaskets.
Rookie is offline
