Merlin Heads V/R for 588 CI SC >
Old 11-09-2009 | 02:54 PM
Default Merlin Heads V/R for 588 CI SC
world merlin v/r 345 119cc steel heads fully ported and polish with severe duty valves 2.25 and extreme duty 1.94 blue print heads with big valves for $1,500 is that a good price?
sosatime is offline
Old 11-10-2009 | 12:11 AM
articfriends's Avatar
I would want to see legitimate flow numbers on them on a known flow bench. I had merlin vr's before and flow wise they sucked,especially on the exhaust side until exstensive porting,Smitty
articfriends is offline
Old 11-10-2009 | 08:39 AM
I would be looking for some aluminum heads to put on a 588 sc engine. You will need the aluminum to take full advantage of the supercharger.
If you feel you must run cast iron heads, I would probably look for a different head if you want to make the most power you could.
Eddie
Young Performance is offline
Old 11-10-2009 | 12:25 PM
Default Aluminum Heads Affordable?
What aluminum heads can I buy for a reasonable price? which heads do you recommend.
sosatime is offline
