Transom assemblies?
Old 11-10-2009 | 11:41 PM
2112's Avatar
Question Transom assemblies?
Anyone know if (on 04' and newer models) the factory uses 5200 or the like to "glue" the transom assembly to the outside of the boat?
I was hoping someone out there knew first hand before I attempt disassembly. .
2112 is offline
Old 11-11-2009 | 08:44 AM
Smitty's Avatar
I would say call the company that built the boat.
Smitty is offline
Old 11-11-2009 | 10:34 AM
They aren't suppose to. There is a foam rubber gasket that seals to the transom. Now, thats not to say that the boat builder didn't put something on the gasket. I have seen it happen one time where the builder put silicone/adhesive on the gasket. It is designed to go on dry. Good luck.
Eddie
Young Performance is offline
Old 11-11-2009 | 10:40 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I'd think the sealing is a Merc specified recommendation, not the boat builders???
US1 Fountain is offline
Old 11-11-2009 | 02:52 PM
2112's Avatar
Good Idea, I have corresponded with Bud at Cig, put in a e-mail Monday, he may be at KW...hasn't gotten back to me yet.
Eddie
Exactly what I do not want to have.
2112 is offline
Old 11-11-2009 | 07:13 PM
Are we to assume that you have a Bravo One outdrive?
See #14 for the O ring rubber gasket. Merc does glue the gasket to the housing. Second the dry install. If you wish an additional sealant, apply a 4200 or 5200 3M sealant bead on the outside edge of the housing/transom.
http://www.mercruiserparts.com/Show_...GIMBAL+HOUSING
ROTAX454 is offline
Old 11-11-2009 | 07:18 PM
2112's Avatar
Default Yikes! 5200?
Yes, Bravo XRs on ITS transom assemblies.
5200, in my opinion, is for something you really never want to disassemble again.
2112 is offline
