Baja Stereo install/mounting question??
Hey Guys!
I am looking at upgrading the stereo in my 24ft Outlaw, there IS a system in it now, so, its pretty straightforward, but, I am not sure how to remove the existing amps from the bulkhead? [between the cabin/cockpit] the amps are mounted on the "drivers" side inside the cabin [where most people mount them] I cant get my hand "behind" the bulkead or between the cut out for the cabin door opening, so, I assume the actual panel in the cabin comes down?, any idea how?, there is an "arch" about 2 inches wide that mounts across the top of the bulkhead from side to side, it "appears" that this is what prevents the bulkhead panel from coming down, do I remove this?, how is it done?, I dont want to damage anything, or have it looked "butchered" when I am done, so, I would appreciate someone telling me the correct way to do it, Thanks in advance!
Michael
Michael
I am not sure abou the 24 Outlaw, I have the 25 Outlay and I can get to the bulkhead by removing the lower dash panel and the fuse box that is under the steeting wheel. I think the 24 might be diffrent but not for sure. Did you post anything in the Baja Form? Brian
