28-29P Standard Bravo Spinelli Prop RH >
Old 11-16-2009 | 06:42 PM
Boater8987's Avatar
Airking
Default 28-29P Standard Bravo Spinelli Prop RH
Anyone have a need for this Custom 14 3/4 by 29 Spinelli standard shaft bravo 4 blade Star propeller. I have over $800 invested, average condition. Started out as a 29P sent back for adjustment for more RPM may be closer to 28. Good for cat or v- bottom, good bow lift and speed. $350 + fgt or make offer. Need to get this out of garage. Call Gary 703-477-9071
Attached Thumbnails 28-29P Standard Bravo Spinelli Prop RH-p1000882.jpg   28-29P Standard Bravo Spinelli Prop RH-p1000886.jpg
Boater8987 is offline
Old 11-17-2009 | 11:55 AM
Do you know how old the prop is and has it been labbed , it looks a little rusty but in good shape. Did it get repitched to 28, was it stamped a 28 scott
fastscarab22 is offline
Old 11-17-2009 | 09:36 PM
Boater8987's Avatar
Airking
I purchased the prop sometime in the early mid 1990's before bravo 1's where avalible. 4 blade "Custom" props were the only ones avalible at the time. I used it on a 1987 Baja Sport 240 with 750 HP 565 C.I. Blower motor. It was the only prop that would hook up, not throw pieces of blade off, good top speed and fly the hull well. I am not sure on exact dates I had maybe 50-75 hrs on it and then moved on to a different boat. It has been in the box since around 1997. As far as lab goes I was under the impression that is why it cost so much. I am not sure on the repitch. I sent it back a couple of times to gain 200-300 RPM The prop is in good condition, they painted the thru hub black and it is more dirty than any rust where the paint has come off. The rear spacer and lock washer is incorporated into the prop. All you need is a lock retainer and prop nut, standard merc stuff.
Thanks for the interest.
Old 11-21-2009 | 11:46 AM
I know it is going to be to much prop, but i would love to try this prop, how about 200.00 for prop and 25 to ship it . Dont really thing i have hp to spin it high enuff but i am a buffalo boy and spinille was in rochester
Old 11-22-2009 | 10:29 AM
Boater8987's Avatar
Airking
I will take $275 + FGT. If I can't get that I guess it will be sitting for another 10 Yrs. This prop would be a great spare for that little money, but you have to have the HP to turn it.
Old 11-22-2009 | 12:01 PM
Will you split the differnce, then it could be done . my hp is 540 do you think i can spin it to 5300
Old 11-24-2009 | 03:45 PM
Went to pier proppeler and they had a 26 , they had in a box on the floor, i guess i will not need yours thanks anyways ( wanted something under the tree )
