Maintenance with a Whipple >
Old 11-16-2009 | 11:29 PM
Default Maintenance with a Whipple
If you put a Whipple on a 502 with say 300hours on it, intending on running it medium, not killing all the time, but having fun once in a while, how does that affect maintenance and maintenance intervals?
thanx
bert4332 is offline
Old 11-17-2009 | 01:04 AM
What kind of maintenance are you talking about????
Oil changes should be done every 25-30 hours and probably spark plugs once a year. Change the blower lube every 25-30hrs as well for added protection.
Griff is offline
Old 11-17-2009 | 02:12 AM
I would think you would want to do the drive lube at the same time you do the oil changes too.
Racerngr1 is offline
Old 11-17-2009 | 05:27 AM
If you just bolt it on without doing MAJOR head work you're asking for trouble. Is it EFI??
Rattlesnake Jake is offline
Old 11-17-2009 | 10:59 AM
Cat & Mice's Avatar
I put a Whipple on my 502 back in 1999. I put about 150hrs on it and never had an issue. I changed the oil in the spring and once during the season. the guy that bought it from me put over 500hrs on it and never did anything but oil changes.
It had a bravo 1 with no issues. It was a Eliminator 28 Eagle V.
I didn't change anything on my heads either. Can't imagine why not doing anything to your heads would make it more of a problem?
MP
Cat & Mice is offline
Old 11-17-2009 | 11:14 AM
animalhouse's Avatar
We installed a pair of whipple chargers on otherwise stock merc. 525's, and ran very hard. Never had any issues to speak of. Maintenance should be top priority, oil changes, and supercharger oil changes are very important, as well as checking valve lash.
If you don't perform maintenance, you will be performing repairs, but that goes for anything.
animalhouse is offline
Old 11-17-2009 | 11:20 AM
How much Boost did you run??
650 Hours on a SC engine with no issues is pure luck, or it wasn't run HARD.
Old 11-17-2009 | 11:35 AM
Charter Member#1545
MP
Mike, how goes it???? How is Todd Kelson??? Have not heard anything about you guys in years now. Like you dropped off the boating radar screen.
Sam
Neverfastenuf is offline
Old 11-17-2009 | 12:02 PM
BLee's Avatar
Charter Mod
You'll be better off with the Whipple, than if you installed a "roots" blower. The Whipples are much more efficient, and much easier on the engine than the blowers of "old". Doing head work isn't completely necessary, unless you're wanting to really turn it up. I would probably have the heads redone just for piece of mind if it were my boat. Make sure you have a good tune, and good timing as well.
You should see a HELL of a difference!
BLee is offline
Old 11-17-2009 | 12:09 PM
Cat & Mice's Avatar
It was whatever Whipple recommended, I can't remember what is was.
And I meant to say it had over 500hrs on it not 150 plus 500, sorry.
I think it may have ended up with almost 600hrs though.
