Can these options be added AFTER delivery?
I'd like to add a few things that didn't come on my boat. If I could even do it myself, I'd still like to do it the same way Baja would to maintain the look, feel, and hopefully waranty. The options I might like to add are:
- Captain's Call
- Custom Steering Wheel
- Trim tabs, double ram with indicators
- Kiekhaefer controls with trim controls on handle
- Carbon Monoxide detector
- Fume detector
- Fresh water flush
- Fire extinguishing system
- Compass
- Transom shower
- Bimini Top w/ Boot
If anyone has a hammer that has these options, I'd appreciate it if you'd post some pictures showing how and where each is installed, and if you know who made the parts, I'd love to know.
Thanks!
- Captain's Call
- Fume detector
- Fresh water flush
- Compass
- Transom shower
Thanks!
All of the options you stated you could install yourself. The hardest thing would probably be a transom shower. For that you would need a pump and a water source. I don't know much about them, but I thought they usually worked off of a fresh water holding tank. That obviously would add some weight to the boat.
You might want to look into in-line-mufflers instead of Capt's call. It would be a lot easier to do. I also wouldn't mess with a halon system. You still technically have to take it out and get it certified every year. I just bought a fire extinguisher to show the cops when I get stopped. I was thinking about doing a transom shower too, but I already have the fresh water tank and a pump for the sink in the cabin. That too would be a lot of work. The fume detectors would be easy to do. Do you have trim tabs at all now? Your throttles would probably be pretty easy to change too.
I just put a sweet MOMO wheel in my boat and if you would like a deal on my old wheel I can send you a picture if you want. I have the transom shower and I think it would be a snap to install as long as you have room for the tank and a power supply. Captains Call is nice but costs a ton. The throttle controls would probally be not too bad if the fiberglass is set up already and you just need to cut. If you are doing fine without tabs now I would not bother unless you have a fat friend that always sits on one side of the boat. My wheel is off a 2001 25 outlaw. It has the red inserts but you can get any color you sant from baja. I would let it go for a good price, say maybe $75.00. my new Momo was 170.
