Where can I buy 1" airex??? Only need like a 2' X 2' piece... >
Old 11-19-2009 | 10:04 PM
Default Where can I buy 1" airex??? Only need like a 2' X 2' piece...
Anybody????
302Sport is offline
Old 11-20-2009 | 06:09 AM
Audiofn's Avatar
Charter Member #232
Try Composite One in RI. Not sure if they will sell you a small piece or not. You could try calling up Outer Limits and other builders in the area and see if they can cut you a piece.
Put your best foot forward!
Audiofn is offline
Old 11-20-2009 | 07:26 AM
mrv8outboard's Avatar
coolrunning racing
You could also try Jamestown Distributor's. They might. Oh they are in RI as well.
mrv8outboard is online now
Old 11-20-2009 | 07:28 AM
thanks guys, ill give them a try.....
302Sport is offline
Old 11-20-2009 | 07:53 AM
no luck, they'll only sell whole sheets, anybody else???
302Sport is offline
Old 11-20-2009 | 11:13 AM
Audiofn's Avatar
Charter Member #232
How much is a sheet?
Audiofn is offline
Old 11-20-2009 | 12:12 PM
$500 or something crazy
302Sport is offline
Old 11-20-2009 | 01:18 PM
glassdave's Avatar
Neno the mind boggler
what do you need it for? i have some pieces of scored 3/4 that are at least 2'x2'
08 OPA High Points Champion
glassdave is offline
Old 11-20-2009 | 01:25 PM
i need it to close off a section of my door to the cabin. my boat used to be a race boat and when they cut my door opening they cut it to close to the gauge panel, and it started to crack from the top of the door towards the gauge panel, because it is only like a 2 inch strip. so I am going to close back off the horizontal part of my opening, re-glass all the old gauge panel openings that arent being used anymore, and behind the dash, the whole width of the dash put two more layers of glass......im just trying to stiffen up that part of the boat
302Sport is offline
Old 11-20-2009 | 01:40 PM
Audiofn's Avatar
Charter Member #232
Could you use lighter density foam? Or plywood?
Audiofn is offline
