How should I go about fixing my skeg? >
Old 11-22-2009 | 04:56 PM
Default How should I go about fixing my skeg?
I just got a bravo setup for my boat switching from and alpha and the skep looks like it was broken and cut and it is also bent abit. Should I get a new skeg welded on or could i get away with a skeg guard
twistedvelocity is offline
Old 11-23-2009 | 07:29 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
It depends on how badly it is really damaged & where on the skeg it is dammaged.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 11-23-2009 | 11:28 AM
A lot of it depends on how fast the boat is. If the boat is going to run over 60 mph, then a bent skeg will have adverse affects on how the boat handles. The best thing to do is to disassemble the lower and have a new skeg tig welded on. Any competent welder can do the welding, but I would have someone that knows outdrives disassemble and reassemble the lower. Good luck.
Eddie
Young Performance is offline
