elbows?
Old 04-10-2002 | 11:52 PM
crmax's Avatar
Default elbows?
Im putting a thru hull exhaust on my boat, how do you remove the elbows to the thru prop they are on tight and I dont want to damage anything
crmax is offline
Old 04-11-2002 | 02:02 PM
formula31's Avatar
Do you mean the elbow attached to the manifold or the one with rubber couplers on each end? If its the one with the rubber, loosen all the clamps real good and try and turn it some to break it loose. Sometimes you have to stuff a screwdriver between the rubber and the elbow to break the seal. It aint always easy.
Tom
formula31 is offline
Old 04-11-2002 | 05:30 PM
are you talking about the y pipe looks more like a u but raps around under the bellhousing and is held in with 4 bolts?James
FloridianSon is offline
Old 04-11-2002 | 06:34 PM
crmax's Avatar
its the part with the 2 rubber couplers between the y pipe and the manifold elbow
crmax is offline
yates90
8
03-20-2012 08:30 AM
gripit
1
10-19-2008 02:20 PM
Aqua Banshee
Wanted
0
10-02-2008 11:19 AM
dyno
06-13-2006 08:46 PM
Sydwayz
08-24-2005 08:52 PM
