Skater 32
Old 11-25-2009 | 06:38 AM
Default Skater 32
how can I know if a Skater 32 is a vinylester or Epoxy lay-up, so as to decide whether the tanks need to be redone or not?
blueprint is offline
Old 11-25-2009 | 07:16 AM
tssteph's Avatar
call skater with the HIN.
tssteph is offline
Old 11-25-2009 | 09:42 AM
Brad Zastrow's Avatar
Polyester resin is the most common resin in boat building. Gasohol eats the tanks. A quick way to know is pull the water seperators filters and look at the top of the filter for gooey material. I had a Motion that was so bad it killed an engine when the filter klogged up. Epoxy has issues also. Vinylester is the good stuff for gas tanks with alcohol. Do a Goggle search on those resins.
Brad Zastrow is offline
Old 11-25-2009 | 09:48 AM
Like Steph said call Peter H @ Skater he knows his boats ,and you probably dont want to hear it but it will need to be going back to Douglas
Dreyden Performance Marine
DrydenPERF is offline
Old 11-25-2009 | 12:45 PM
2112's Avatar
Can someone educate me as to why they are not using aluminum tanks? Is it that much of a weight savings to accept the potential grief.
2112 is offline
Old 11-25-2009 | 01:15 PM
Default Skater 32
on which part of the hull is the HIN found?
Old 11-25-2009 | 06:08 PM
I would say mainly for weight. A 3/16" aluminum tank with foam weighs about 1 lb per gallon of capacity. Many of these boats (i/o's) were not cg approved with these tanks. The reason for not using a bladder (also usually not cg approved) would be cost as the added weight is very small and if the bladder failed the fuel would be in what they are calling a fuel tank anyway. I am surprised they never used the bladder foam in these cells as it burns like a candle rather then the big blowup.
This was an easy area to save a little money and have a 200lb or more edge on the competition.
Steve
smiklos@sunprint is offline
Old 11-26-2009 | 05:16 AM
Audiofn's Avatar
Charter Member #232
Allum. tanks fail also...
Put your best foot forward!
Audiofn is offline
