Can fiberglass exhaust tubing be replaced with stainless? >
Old 12-01-2009 | 10:07 AM
Default Can fiberglass exhaust tubing be replaced with stainless?
I was wondering if there would be any problem replacing the fiberglass tubing in the exhaust with stainless?
twistedvelocity is offline
Old 12-01-2009 | 10:48 AM
glassdave's Avatar
Neno the mind boggler
where do you have fiberglass tubing in your exhaust? I cant imagine there would be any prob going with all SS, thats the way it should be anyway.
08 OPA High Points Champion
glassdave is offline
Old 12-01-2009 | 12:47 PM
It goes from my risers to my side exhaust. Right now there is even a big fiberglass muffler. But I see the elbows are cracked. My buddies boat has basically the same setup but no mufflers. I was just wondering if the fiberglass was used to keep heat down in the engine bay or anything? And if the stainless would cause any problems
Old 12-01-2009 | 01:06 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Will just add a little weight, but won't have to worry about them cracking. My Pachanga had the same setup as yours, but had the AL elbows.
US1 Fountain is offline
Old 12-01-2009 | 11:59 PM
I would think it wouldn't be too bad for weight if I used a tubing like exhaust tubing in trucks
Old 12-02-2009 | 06:47 AM
C_Spray's Avatar
Diamond Member #001
Try to get 316 or (better yet) 316L stainless. Typical 304 stainless is not as corrosion resistant as you might think. Stainless Marine (Google them) could probably supply whatever you need.
Remember - a leak in a wet exhaust system can sink your boat.
C_Spray is offline
Old 12-02-2009 | 10:51 PM
What about maybe using aluminum?
Old 12-02-2009 | 11:51 PM
I would go straight to the 316L SS and don't bother with the aluminum. It will eventually corrode, even in fresh water. The calcium, magnesium, etc. in fresh water will eat up the aluminum exhaust tubing. Once you do it with SS, you will never have to worry about it again.
Eddie
Young Performance is offline
Old 12-03-2009 | 12:21 AM
Has anyone done this and have an idea of what the cost would be?
Old 12-03-2009 | 08:52 AM
AIR TIME's Avatar
Red face
I whats the headers made of 316 or 304 theres some companys that use one for headers and the other for there tails. so which is a better ss 304 or 316. I will go to the web sites see who uses what.
AIR TIME is offline
