Single Engine Twin Drive >
Old 12-04-2009 | 12:12 AM
Default Single Engine Twin Drive
Geared Up System
Anybody know anything about there product?
I was thinking about buy a 36' cigarette with some burnt out engines and replacing them with a single 480hp Yanmar diesel with twin bravo ones. Splitting the torque, so it should have no problems for the bravos. Seems like a simple inexpensive and fuel efficient system. I know the 480 is much more efficient than twin 315's. And I haven't heard great things about he bmax diesel drives.
I remember reading somewhere about a chain drive system in some of the typhoon boats. Anyone know who was making that?
Is there anything bad about having twin drives connected to a single engine?
fpjeepy05 is offline
Old 12-04-2009 | 05:24 AM
Mastry Engine Center in St. Petersburg, FL has the setup you're looking for and is a Yanmar distributorship, 727-521-4661
Scott H. is offline
Old 12-04-2009 | 08:30 AM
There was an article in Powerboat a while back about a twin drive single engine setup. Lots of power loss, lots of drag. I think I would rather have it the other way around, two engines and one very beefy drive. For a diesel not real speed demon it may be good to split the power.
Pismo10 is offline
Old 12-04-2009 | 10:12 AM
IMCO made a gearbox for a two drive/one engine setup a few years ago. It was a sharp looking piece. The only problem I see is that the boat will be a slug with one 480. I would think it would work good if you put more power in it.
There are quite a few monetary benefits to a single engine, however, if you have a problem, you are coming in on the end of a rope. It sure is nice to have that backup engine.
Eddie
Young Performance is offline
Old 12-04-2009 | 10:16 AM
There was a 35 Nordic with something like a single 1200hp and the Imco splitter. I think the re were problems with the gear box.
480hp in a 36 Cig???? You'd be lucky to hit 50mph.
Griff is offline
Old 12-04-2009 | 04:40 PM
Wouldn't it simply be better to mate the 480 to a SSM V drive. Costs less, and fewer parts to break. A used SSMV, is quite reasonable.
Darrell.
DMOORE is offline
Old 12-04-2009 | 05:01 PM
Smitty's Avatar
Waaaaayyy underpowered.
Smitty is offline
Old 12-04-2009 | 06:54 PM
Originally Posted by fpjeepy05
Geared Up System
Probably be a heck of a lot cheaper and easier to just throw a couple stock big blocks in it. You will never be able to resell it with a single.
specialk is offline
Old 12-04-2009 | 09:26 PM
Darrell.
and still won't do 50 mph. Maybe a seatec diesel and a single #5 or an Arny.
fastdonzi is offline
Old 12-05-2009 | 08:17 AM
I agree, going to be a trawler version of a perf boat, use 2 if you do it...
ezstriper is offline
