What's the GPH on a Merc 850sci >
Old 12-04-2009 | 10:51 AM
Strip Poker 388's Avatar
Rob
Question What's the GPH on a Merc 850sci
What is the GPH on the new style Mercury supercharged 850's and 700's??
Im sure the smart craft stuff tells ya ,What have you all seen?
Rob
Strip Poker 388 is offline
Old 12-04-2009 | 10:56 AM
Sean H's Avatar
A to Z
850 (race) is about 60 gph
Sean H is offline
Old 12-04-2009 | 03:01 PM
Rob
is that wfo?
I would of thought it would of be higher
Old 12-04-2009 | 03:08 PM
Sean H's Avatar
A to Z
thats pretty much an average number for a race, so yeah, pretty wfo...
Sean H is offline
Old 12-04-2009 | 03:22 PM
HUSTLEthis's Avatar
Had to laugh.....
HUSTLEthis is offline
Old 12-05-2009 | 01:36 AM
From what I have seen, EFI engines are generally pretty close to the HP divided by 12 for the WOT GPH usage.
Griff is offline
Old 12-05-2009 | 10:00 AM
AppSysCons's Avatar
Yes, that is pretty much what I was thinking, based on other Merc EFI engines. That puts the 850 closer to 70gph.
AppSysCons is offline
Old 12-05-2009 | 10:56 AM
Sean H's Avatar
A to Z
mid corner, drives turned, engines bound up and accelerating, you might get 65-67 gph, wfo in a straight line the engines really don't burn that much, especially in a cat.
Sean H is offline
Old 12-05-2009 | 11:34 AM
AppSysCons's Avatar
Cat, V or cruiser, does not really matter that much.
For a given engine, if you make constant HP, for a specific period of time, you will burn relatively the same amount of fuel, in any boat. Weather we speak in terms of megajoule (MJ), or British thermal unit (BTU), a gallon of 93 gasoline, has a constant energy content, and can produce a specific amount of HP, in a given engine, regardless of the work the engine is doing. Remember 1 mechanical HP is equal to 550 foot-pounds per second, which is approximately equivalent to 745.7 watts, at does not matter how they are used, they take the same energy to produce.
If you run WOT for a specific period of time, the same engine in the cat, will get farther than the V, and the V will get father than the cruiser, but they will all burn virtually the same amount to fuel.
Old 12-05-2009 | 11:42 AM
Sean H's Avatar
A to Z
I understand that, I am just telling you we burn more fuel on acceleration courses than we do top speed courses. It only varies by a few gallons per hour. We account for the 60 GPH and usually have fuel left over actually.
and my notes from Merc say 62 gph for the race 850.
Sean H is offline
